2003 Chrysler Sebring vibration
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEROD47
  • 14 POSTS
need to know if axle driveshat will cause vibration at around 30 mph above that gos away below that goes away relace hub bearings with no luck they tell me it could be differenal bearing ty
Sep 19, 2009 at 1:21 AM
  • 110,246 POSTS
Usually when it comes and goes as described, it's simply tire balance. Where do you feel the vibration most, in the steering or the seat?
Sep 20, 2009 at 1:30 PM
JOEROD47
  • 14 POSTS
ITS LIKE A RUMBLING NOISE THEN THE MORE U DRIVE AND MAKE TURNS U HEAR LIKE CLICK NOISE AND I RELACE UPER BALLJOINTS THEY WERE LOOSE
Sep 21, 2009 at 12:55 AM
  • 110,246 POSTS
If you are hearing a clicking noise when turning, chances are you have a bad CV joint.
Sep 21, 2009 at 12:59 AM
JOEROD47
  • 14 POSTS
is there anyway to repair or will u recommend replacment at 89.000 miles ty for your help
Sep 21, 2009 at 2:00 AM
JOEROD47
  • 14 POSTS
is it normal to go bad like that or should i look for something else that made it go bad
Sep 21, 2009 at 2:02 AM
  • 110,246 POSTS
It isn't uncommon. You will need to replace it. Most people just replace the "half shaft" which is the axle with two new CV joints. THat is most likely what I would recommend for you.
Many times the boot will rip in them allowing the grease to spin out and dirt to enter. That is usually the cause of failure.
Sep 21, 2009 at 1:43 PM
JOEROD47
  • 14 POSTS
hey thanks for your help remove cv axle check for looseness found outer cv loose replace noise went away ty
Sep 24, 2009 at 12:38 AM
  • 110,246 POSTS
I'm glad you got it fixed. If you have questions in the future, let us know.
Sep 24, 2009 at 3:17 AM
JOEROD47
  • 14 POSTS
left an toyota quetion no anser it a chqllenge i know ive hade the trans apart twice with no success any help would be greatfully appreciated
Sep 24, 2009 at 11:46 AM
  • 110,246 POSTS
Can you cut and paste the posting? I will never find it otherwise.
Sep 24, 2009 at 12:18 PM
JOEROD47
  • 14 POSTS
joerod47 wrote:
Transmission problem
1987 Toyota Tercel 4 cyl Two Wheel Drive Automatic 160000 miles
need help please after removing trans for differential problem decideto rebuilt trans for high miliage trans was fine just wanted to put new clutches and seals in it now it wont shift it goes into drive & reverse but wont shift check governor ok check bearing location ok 6 ball bearings in it valve body vale ther is movement wat am i missing ty trans a55 2w drive
when it shifts feel like it is going into reverse ty
Sep 24, 2009 at 9:16 PM
  • 110,246 POSTS
When you had things apart, could you have damaged the shift solenoid wire?
Sep 25, 2009 at 12:10 AM
JOEROD47
  • 14 POSTS
there no wires just valve and it seem just about to shift its like going in reverse but not completly there is no bands eathier it all clutches it has good drive
&reverse application im thinking it in the valvebody but im not sure
Sep 25, 2009 at 12:16 AM
  • 110,246 POSTS
Is the linkage placing the trans in gear properly (not out of adjustment)?
Sep 25, 2009 at 1:01 AM
JOEROD47
  • 14 POSTS
yes it is i check that yersterday
Sep 25, 2009 at 1:26 AM
  • 110,246 POSTS
Did you take the valve body apart?
Sep 25, 2009 at 3:20 AM
JOEROD47
  • 14 POSTS
im thinking in could be leaking in the second cluth pack im going to pull tranny again go true it one more time never delt with this one before its all clutches no band ty anyway later
Sep 25, 2009 at 5:56 AM
  • 110,246 POSTS
It's been awhile, but if I remember correctly, one clutch pack takes care of low and reverse. Since you have both of them, I agree with you on the 2nd. However, I question if the clutch pack would cause this problem.
Sep 25, 2009 at 6:39 AM
JOEROD47
  • 14 POSTS
well im thinking there is a leak upon application so im going to remove it and air test im thinking its applying but dissengage because of an oil pressure leak. see if it makes sense
Sep 26, 2009 at 1:25 AM
  • 110,246 POSTS
Let me know what you find.
Sep 26, 2009 at 4:48 PM
