2003 Chrysler Sebring skipping
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEGSMITCH15
i have an '03 sebring and we ran into problems about a week ago when it got really cold and it wouldnt start, we changed all of the plugs and wires and everything was fine. Tonight i went to drive it and the check engine light popped on, when i accelerated above the 2 on the RPM meter it started to kick back or skip sort of like before we replaced the plugs. It shouldnt be the plugs if we just got them replaced i wouldnt think....if you have any insight that would be great.
Feb 11, 2008 at 2:41 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f9ba666388="megsmitch15"]Engine problem
2003 Chrysler Sebring 4 cyl Two Wheel Drive Automatic 95,000 miles
i have an '03 sebring and we ran into problems about a week ago when it got really cold and it wouldnt start, we changed all of the plugs and wires and everything was fine. Tonight i went to drive it and the check engine light popped on, when i accelerated above the 2 on the RPM meter it started to kick back or skip sort of like before we replaced the plugs. It shouldnt be the plugs if we just got them replaced i wouldnt think....if you have any insight that would be great.[/quote:f9ba666388]
recheck the wires and the work you did
you need to read the codes
cycle key on off 3 times endind with key on read codes
let me know
Feb 13, 2008 at 10:19 AM
