I just rebuit a 2.7 liter dual cam flex fuel engine.It has code P0340 on it. when I unplug the sensor the engine will run fine. I have check and verified that the sensor has 8 volts on it. When I took the sensor out and put metal in front of it the fuel pump turned on. I repeatedly did this. Everything was replaced in the engine. What I read talks about preforming verification test # 5 ngc. Will this reset something in the PCM that will allow this motor to start properly. What does ngc stand for.Is there a
procedure that can be done to fix this problem without the DRBIII scan tool.
Oct 30, 2010 at 2:47 AM
