2003 Chrysler Sebring need help
2003 CHRYSLER SEBRING
11,000 MILES • 6 CYL • FWD • AUTOMATIC
SMARTIN25
2.7 liter dual over head cam flex fuel (t) runs great but some times when i come to a stop the oil light will come on and the engine rattles from the top end and then stop and run fine it is getting worse . when i first start it it chatters then quits . i assume the oil pump is going out! any comments or ideas would be great
Mar 28, 2009 at 8:06 AM
CARADIODOC
  • 34,381 POSTS
110,000 is a lot for this engine. Sludge forms in the oil if it isn't changed at exactly 3,000 miles. You could try a chemical flushing agent in the oil just before the next oil change, but chances are it's time for an engine rebuild.
caradiodoc
Mar 29, 2009 at 2:47 PM
