2003 Chrysler Sebring i got a P0344 code
119,000 MILES • 4 CYL • 2WD • AUTOMATIC
JUNIOR37
my car recently started surging once the car reaches 2400 rpms regardless of what gear i am in. I have changed the ignition coil and i have had new plugs and wires put in. i also noticed that when the ignition is in the on position my cruise control lights up like it should, but when i actually have the car running ...there is no cruise light on the dash and it doesn't work. any ideas would be helpfull
Apr 23, 2008 at 8:35 AM
BMRFIXIT
  • 19,053 POSTS
you need to check and replace cam sensor
https://images.2carpros.com/forum/automotive_pictures/99387_camsensor_2.jpg
Apr 26, 2008 at 2:34 PM
JUNIOR37
Apr 27, 2008 at 12:06 AM
BMRFIXIT
  • 19,053 POSTS
and still have code p0344
you need to check the wiring harness
Apr 27, 2008 at 12:58 AM
JUNIOR37
[quote:10ceafcb78="BMRFIXIT"]and still have code p0344
you need to check the wiring harness[/quote:10ceafcb78]
ok thanks but would you know exactly where i should start, or could it be anywhere in the wiring harness
Apr 27, 2008 at 3:02 AM
BMRFIXIT
  • 19,053 POSTS
Unplug cam sensor and check plug and wiring
using volt meter check for volts supply
check for a ground
Brown is ground (behind center of dash
blue/yellow is terminal #56 at the PCM
red is power and connect to injector wiring harness
Apr 27, 2008 at 3:36 AM
