2002 Chrysler Sebring Trembling while braking
2002 CHRYSLER SEBRING
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
MORENA0107
I have changed the front rotors of this vihicle and the car was running fine, but after about 2 weeks the trembling started happening again when I brake. What can this be?
Apr 7, 2009 at 10:34 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Have the new rotors machined. You probably installed the less expensive Chinese rotors. There's nothing wrong with them except they were "aged" on your car. Cast iron parts made in the U.S. are set outside for 90 days before the final machining is done. Any warping takes place before that final step. The Chinese don't age their parts first; they just cast them, machine them, and send them on their way. Once machined after they warp, the problem is not likely to occur again.
If it does happen again, chalk it up to do-it-yourselfer-itis. It is extremely important that the lug nuts be tightened to specifications with a torque wrench. 95 ft/lbs is common for most Chrysler front wheel drive vehicles, but double-check for your car. If you don't use a torque wrench, you can expect warped rotors again in the future.
caradiodoc
Apr 8, 2009 at 1:47 PM
