2002 Chrysler Sebring Noise in stut tower
RICKYD
Suspension problem
2002 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
I,ve just replaced the ps side cv axel and every time I drive over the slightest bump the strut springs sound loose. I noticed that on the struts where you attach it with the 4 bolts under the hood, can I tighting or loosen that nut so that the springs can stop rattling.
Thanks.
Mar 17, 2009 at 6:12 AM
ZACKMAN
  • 4,202 POSTS
Those bolts are supposed to be tight. But I don't think that is your problem. You need to check your ball joint, sway bar link and engine mount, as well.
Mar 17, 2009 at 3:39 PM
