2002 Chrysler Sebring Heating problems
2002 CHRYSLER SEBRING
99,500 MILES • 6 CYL • FWD • AUTOMATIC
WHITTLEY
When my heater is on, I only get hot air out of the passenger side vents. All the vents on the drivers side blow cool air. This remains true no matter what setting I have it on ( floor, defrost, front ).
I checked the coolant in the car and it is full so i know that this isn't the problem.
I have also tried the air conditioner which is working fine. All vents blow ice cold air when on.
Oct 21, 2009 at 5:11 AM
BMRFIXIT
  • 19,053 POSTS
Suspect bad blend door actuator
try and re-calibrate the system by disconnecting negative battery cable for one min and reconnecting it back
start and run the engine
need to have it checked for codes
check for BCM ,HVAC related codes
Oct 21, 2009 at 1:02 PM
