2002 Chrysler Sebring heater
61,000 MILES • 6 CYL • FWD • AUTOMATIC
JOEFANT
My heat stopped working. The blower works and there is no water on the floor. Where is the thermostat and can it be replaced without draining the coolant?
Nov 9, 2008 at 4:18 AM
  • 110,251 POSTS
Hi:
You will find the thermostat at the end of the upper radiator at the engine. The hose connects to the t-stat housing. You will need to remove the two or three bolts holding the housing to actually get tot it. As far as draining the coolant, remember, water seeks it's own level. Therefore, you will need to drain the system below the t-stat level or it will leak everywhere when you remove it.
Nov 10, 2008 at 8:13 AM
