2002 Chrysler Sebring fan motor or switch
MJOHNSON7
  • 2002 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 28,650 MILES
The switch to adjust the fan speed inside the car only works in the 4 or highest setting. When set to either 1, 2 or 3 there is no response. Doesn't matter if heat or air.
Fuses look good
Monday, August 25th, 2008 AT 7:27 PM
MASTERTECHTIM
  • 4,750 POSTS
Replace the blower motor resister. This is the problem, they burn out the lower settings. The new part is updated and built stronger, its held in by 2 screws and is located near blower motor in the heater box
Monday, August 25th, 2008 AT 7:38 PM
