2002 Chrysler Sebring engine wont start
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
EZEDDIE55
i have no current going to the starter and no spark i changed the battery and the ignition switch fuse is good relay is good starter is good what else can i check
Dec 6, 2009 at 10:24 AM
  • 75,988 POSTS
What is it doing ?-Is it cranking over and will not start or just won't crank at all/nothing?? Please! explain
Dec 6, 2009 at 4:25 PM
EZEDDIE55
the engine dont crank, i have no current to starter and if i jumpstart the starter i have no spark at the spark plugs
Dec 8, 2009 at 10:43 AM
  • 75,988 POSTS
Check and test the ignition switch, starter relay and park/neutral switch
Dec 8, 2009 at 11:19 AM
