2002 Chrysler Sebring engine code
55,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOUGLOUGHNER
Getting a code PO440 which is Evaporative Emission
Control malfunction....no idea how or what to fix...
Car runs fine...no problems just the engine light is on and the code reading above....HELP ?
Nov 18, 2009 at 2:52 AM
  • 110,251 POSTS
There is a leak in the EVAP system. It could be a bad gas cap to other leaks. What I suggest is first determine if it is a leak. If so, have the system fogged to identify where the leak is coming from.
Let me know what you find.
Nov 20, 2009 at 3:28 PM
