Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Sebring
Body
Door
Lock
2002 Chrysler Sebring Electrical
2002 CHRYSLER SEBRING
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEESTEFFEN
MEMBER
1 POST
Radio, door locks, mirrows fail to operate, fuses check ok. Where do I look? Thanks Lee
Dec 13, 2008 at 10:11 PM
BMRFIXIT
Experienced Mechanic
Check in the junction block (left end of dash )
fuse # 14 should be hot in RUN or ACC
fuse # 5 should be hot all times
fuse # 5 is the common between all
use a test light check it for power all times
Dec 13, 2008 at 10:58 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
