2002 Chrysler Sebring Electrical
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEESTEFFEN
Radio, door locks, mirrows fail to operate, fuses check ok. Where do I look? Thanks Lee
Dec 13, 2008 at 10:11 PM
BMRFIXIT
  • 19,053 POSTS
Check in the junction block (left end of dash )
fuse # 14 should be hot in RUN or ACC
fuse # 5 should be hot all times
fuse # 5 is the common between all
use a test light check it for power all times
Dec 13, 2008 at 10:58 PM
