when i open the switch to start the car ,it does't do anything,no cranking,all lights on instrument cluster are off.check engine light,gas,oil,battery,etc.also this car has another problem.mechanic already replace cam sensor because when i drive the car some times shakes then shut off after trying many times car only cranks three times i took it back to the mechanic what they did is to pull cam sensor out cleaned then put it back car start again i had to do samething but with old sensor car start but about aweek later same thing this happened 5 times.i guess could be cam sensor conector.please i need your help. thank you
Mar 21, 2009 at 7:35 AM
