2002 Chrysler Sebring
116,000 MILES • 6 CYL • FWD • AUTOMATIC
ANJCANNIFF
My check engine light came on today as i was driving down the highway. i was holding the gas pedal down to stay at an even 55 mph, and the car started jerking. the rpm needle kept shaking real bad between 2 and 3. couple days ago, went to leave, car wouldnt start. checked some stuff, found a burnt out fuse, changed it and the car started fine. ran the same until today. any help?
Nov 6, 2009 at 4:17 PM
  • 31,937 POSTS
Hi there,
The check light is a visual indication that the ECU has logged a fault code, we will need this code to determine the cause of your problem, get a scan done and report the code here.
mark (mhpautos)
Nov 6, 2009 at 8:17 PM
