I have a 2001 Chrysler Sebring LXi 4 door Sedan (2.7L 6 cylinder 4A). It is overheating. The thermostat has been changed, the hoses are not clogged or leaking, radiator cap is in good condition, no noise coming from the water pump, no water in the oil, But when we try to add water/coolant, the engine wont take it. It wont suck the water in through the motor. The water is blowing out all over my drive way and is overheating.
My questions to you are:
Why will it not take in water?
Does the water pump have to make noise to be bad?
By the way it has 120,000 miles. Please help.
Thank you in advance.
PS: This will be the last Chrysler I buy.
Feb 21, 2007 at 2:47 PM
