2001 Chrysler Sebring wheel bearing
TOMMY LARKIN
Suspension problem
2001 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
what size of torque socket do i need to remove the front drivers side wheel bearing
Apr 15, 2010 at 2:54 AM
ERNEST CLARK
  • 1,730 POSTS
Your wheel bearing and hub are one complete unit and there's no single "Hub nut" like on other vehicles.
Your hub assembly is mounted to the steering knuckle and is retained by three bolts on the back. This is an involved process to remove it.
If you're up to the task, it looks like they'll be 13-15mm bolts. Good luck.
Apr 18, 2010 at 12:42 AM
