2001 Chrysler Sebring Trouble Codes
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE VARGAS
  • 5 POSTS
'01 Chrysler Sebring w/ 2.7 liter V6. Car runs very sluggish (missing) when cold. Once vehicle is driven for 10-15 min. & warm, then shut off & rested for 10-15 min., it runs fine - for the most part - still a little missing, but not as bad as when it is cold. I live in Las Vegas, so "Cold" is only in reference to engine temperature. Diagnostic test codes read : P0204: Injector Circuit Open Cylinder 4 - Repair Manual Code P0204 reads: Injector # 4 Output Driver not responding properly. Full tune-up has been done - and all injectors have been removed and cleaned. What is the problem, and what do I need to do to fix it.....Thanks.....
Jun 30, 2008 at 3:39 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Possibly a bad injector. Try switching them out with a different cylinder and see if the code changes over to that cylinder. If so then replace the injector. Otherwise you may have a bad spot in the circuitry or at the ECU pins.
Jun 30, 2008 at 3:59 PM
JOE VARGAS
  • 5 POSTS
[quote:14eeb83415="airsoftsoldrecn9"]Possibly a bad injector. Try switching them out with a different cylinder and see if the code changes over to that cylinder. If so then replace the injector. Otherwise you may have a bad spot in the circuitry or at the ECU pins.[/quote:14eeb83415]
This worked great, and verified that the injector itself was malfunctioning..........Thanks for the help...........
Jul 17, 2008 at 9:08 AM
