2001 Chrysler Sebring missing
DEREK61
Engine Performance problem
2001 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 92.000 miles
missing constantly now , started a few weeks ago , i added some seafoam to the gas and it quit for a couple of weeks ,i found out what cylinder is missing but not sure if its the injector or a plug , i pulled the connector off of the middle front deal over the valve cover , i think maybe this is the fuel injector?? not sure? any info would help , there are six connectors and they hook to what looks like transformer to me but it may be the injectors ... thanks
Jul 23, 2009 at 12:02 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Jul 23, 2009 at 12:05 PM
