2001 Chrysler Sebring leaking coolant
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARISSA1320
i put coolant into the box and 2 days later it is empty it has been to the shop twice they did a pressire test to the hoses and found no leaks in the hoses the car does not overheat nor blow any smoke it looses heat when the coolant is empty in the box. i have to put coolant in every 2 days any suggestions
Feb 9, 2009 at 11:03 AM
TJOLOLO
This sounds like your COOLANT HOUSING IS CRACKED. I say that because I just fixed the same problem with my car in December.
BE VERY CAREFUL!!! because you're leaking coolant, your car will overheat much more easily and you can end up stalling out at really dangerous times. For us we kept stalling/overheating in the middle of intersections. So be warned, this could become a seriuos situation very quickly.
It cost me about $700CAD to replace the coolant housing and thermostat and a few other related items. You WILL have to repair it or the car will become unsafe to drive (see the stalling comments above).
Unfortunately, I recently learned that this is a problem specific to Chryslers; most vehicles don't have problems like this unless they've been in an accident.
So good luck...
Sep 20, 2018 at 11:53 AM
JOHNNY G.JR
  • 320 POSTS
If coolant housing was cracked it would show up somewhere when pressure test was done, It could be a very minor head gasket into cylinder that is not visual yet out the exhaust, I hope not for your sake. Try a compression test on all cylinders to verify or not
