2001 Chrysler Sebring i hear a popping in the wheel when i
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIG_UNCLE_05
when i turn a corner or sometimes when im just driving straight i hear a popping noise. it doesnt do it all of the time but it does it mostly when i make a turn. what could it be? and is it costly??
Oct 30, 2009 at 3:15 AM
JDL
  • 16,098 POSTS
Hi, it sounds like a halfshaft joint. If you do the work yourself, cost you the price of the part and some time. Usually I don't fix the joint, I replace the halfshaft. If you do the work yourself, you may need to get the alignment checked afterwards. I don't know what shop would charge, depends on what they charge for diagnostics and labor, plus the part.
Oct 30, 2009 at 4:33 AM
