2001 Chrysler Sebring heater blows cold
90,999 MILES • 6 CYL • 2WD • AUTOMATIC
BIGO05771
I have a 2001 Chrysler Sebring and the heater has stopped putt out hot air. The thermostat seems to be working and shows normal temp but it does take a long time to get to normal. Is there a fuse or relay hidden some where that may have blown ? What are the most command problems with the heater blowing cold?
Aug 15, 2010 at 12:14 AM
  • 75,988 POSTS
Test the thermostat and check the heater control valve and if the heater core is clogged-up
Aug 15, 2010 at 2:17 AM
