2001 Chrysler Sebring Gas Odor
2001 CHRYSLER SEBRING
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJJHHH88
There is the odor of gasoline inside car, inside engine. THere are no gas leaks. A mechanic told me it was the injectors.
Jul 25, 2010 at 3:48 AM
EDWARD.S
  • 166 POSTS
Hi, It Is Possible For The injectors To been leaking , However ,Have The Fuel Tank ,And lines Checked for Leaks.This Is Done With a Smoke machine .If your injectors are leaking ,You Should be able to see gas Around them .Shine a Flashlight At each injector And see if it's wet with gas.If so You need To get them replaced.ASAP.
Hope This Helps You,
Good Luck
Edward S.
Jul 25, 2010 at 4:03 AM
