2001 Chrysler Sebring Engine Oil Pressure light comes on
56,000 MILES • 6 CYL • FWD • AUTOMATIC
DANISON
The engine oil pressure indicator first started flickering and then continuously started lighting when my car is idle. However when I drive the indicator light is gone.
When I checked the engine oil with the dipstick and the level is normal.
I am scared to show this to a dealer because they will squeeze all money out of me.
I would appreciate a good advise!
May 15, 2010 at 3:38 AM
  • 31,937 POSTS
Hi there,
More than likely this is just a faulty oil pressure switch, your local mechanic can check the oil pressure with a mechanical gauger and if all is OK, just fit a new switch.
mark (mhpautos)
May 15, 2010 at 3:41 AM
DANISON
Thanks for your instant reply. Do you think I should go to a dealer or just show to any car repair shop close by.
Thanks a lot!
May 15, 2010 at 3:49 AM
  • 31,937 POSTS
This is a very simple check, any mechanic can do this.
mark (mhpautos)
May 15, 2010 at 6:35 AM
