2001 Chrysler Sebring
101,000 MILES • 6 CYL • FWD • AUTOMATIC
SHARDEZZY
i have a 2001 chrysler sebring and the engine light came on. we hooked one of the machines up to it and it says ignition coil b. i thought the inition coils were numbered. what is ignition coil b????
Jul 16, 2008 at 3:14 PM
JOE VARGAS
  • 5 POSTS
[quote:92ff6e3b7f="shardezzy"]Engine Mechanical problem
2001 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 101000 miles
i have a 2001 chrysler sebring and the engine light came on. we hooked one of the machines up to it and it says ignition coil b. i thought the inition coils were numbered. what is ignition coil b????[/quote:92ff6e3b7f]
Did it read ignition coil "B", or was it possibly ignition coil "6" (six) ? If it is ignotion coill six, you will need a repair maual - this will give you the numbering sequence of the cylinders/ Each cylinder should have an indepedent ignition coil, aka "coil pack". Which are located at the top of each spark plug. Check for a bad connection at the coil pack of your number six cylinder. If connections are good, then you probably need to replace the coil pack -about $50.00/ stocked at most parts stores. Easy fix - disconect the electrical connector, remove the 2 small bolts at the top of the coil pack - remove and replace with new coil pack. Hope this helps...........
Jul 17, 2008 at 8:26 AM
