2001 Chrysler Sebring
145,000 MILES • 6 CYL • FWD • AUTOMATIC
RNDYHARPER
My key will not turn the ignition key cylinder to start the car. It just suddenly jammed.
Is there a way to get the stering unlocked and the transmission to unlock so we can move car without towing?
Is this a problem with the Ignition key cylinder or is there a switch on the brake that went out. If I remember correctly you have to push the brake in to turn the ignition switch and to take out of park.
Mar 26, 2009 at 4:36 AM
CARADIODOC
  • 34,413 POSTS
Try turning the steering wheel to remove pressure on the lock mechanism while you turn the key.
Mar 29, 2009 at 2:51 PM
