2000 Chrysler Sebring "moaning"
104,000 MILES • 6 CYL • FWD • AUTOMATIC
QUONSET HUT
1). Ever since buying the car in 2000, it "moans" when making a right turn at a slow speed. What is the noise; is it something to be concerned about?
2). Driver-side door latch sticks and will not close.
Feb 19, 2010 at 7:05 AM
  • 110,248 POSTS
IS the power steering fluid full? Do you have any leaks from the rack and pinion? As far as the latch, have you tried a lubericant on the door latch?
Feb 19, 2010 at 3:23 PM
QUONSET HUT
I will check power steering fluid and will have the rack and pinion checked also.
.....door latch problem.....have tried lub in the past; will hit it agiain.
Thanks!
Feb 20, 2010 at 1:26 AM
  • 110,248 POSTS
Let me know what you find.
Feb 20, 2010 at 3:42 AM
