2000 Chrysler Sebring Feul pressure
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
JKK2049
  • 47 POSTS
i recently had a mobile mechanic come out to my house to dignose my vehicle because it would not start. he checked the feul pressure and found that i was only getting about 10 psi. so i went and pulled a feul pump off of a 1996 dodge avenger and installed it..now where he disconected the line to check the pressure, the part in between the throttle and the windsheild wiper fluid resavoir, is leaking when i turn the key and still no start...Could this leak still cause the engine to not start? and i have tightened the crap out of it and still cant get it tight enough... any sugestions on what to do? thanks for all help...
Mar 16, 2009 at 1:34 AM
  • 75,988 POSTS
What's leaking is it fuel? If so it losing fuel pressure EFI system don't like low fuel pressure.
Mar 16, 2009 at 1:44 AM
JKK2049
  • 47 POSTS
it is leaking where he diconnected the line to check the pressure...its leaking gas...
Mar 16, 2009 at 3:28 AM
  • 75,988 POSTS
Get it fix and comeback with some results.
Mar 16, 2009 at 11:09 AM
