2000 Chrysler Sebring 2 windows won't go down
CAITLINLAVIN
I have a Sebring Convertible. The rear driver's side window will not go down at all. The front passenger side window can go down if the driver put's it down but the button on the passenger side doesn't work. Is it related? How can I fix them?
Feb 11, 2009 at 2:36 PM
  • 110,248 POSTS
Hi:
You need to check the switch on the driver's side. I believe power goes through there to the next switch. Check for power to the rear motor too. If you have power, the motor may be bad. If there is no power, you need to determine if one of the switches are bad by checking for continutity.
Let me know what you find.
Mar 19, 2009 at 1:32 PM
