1999 Chrysler Sebring Rough idling and hestitation
1999 CHRYSLER SEBRING
148,000 MILES • 4 CYL • 2WD • AUTOMATIC
DYCGOLF
Sometimes my car run rough at idle and hestitates while hesitating. I was getting a service engine light and the coeds were P0300, P0302, P0303, P0304 which indicated mutlitple cylinder misfires and cylinder 2,3 and 4 misfires.I replaced the distributer cap, spark plugs and spark plug wires. I also put fuel injector cleaning fluid in the tank. It is a little bit better but still the symptoms continues. Is it the ignition coils or fuel injector? If the coils are there two for this car? How much to replaces these parts?
May 18, 2008 at 3:02 PM
LEGITIMATE007
  • 5,121 POSTS
check for vacuum leaks, this is one common cause for these symptoms.
May 18, 2008 at 3:36 PM
