1999 Chrysler Sebring replacing the drive belts
110,000 MILES • 6 CYL • FWD • AUTOMATIC
GOLDIEGOPHER
I bought a HAnyes manual to check and see how to replace these belts. Unfortunately the instructions leave alot to be desired. I am hoping this is an easy change out. Everything looks like close quarters and may be hard to get my big hands into small spaces. So if there is an easy access to the bolts that loosen the power steering module and the alternator I could use some suggestions.
Thank you
May 18, 2010 at 5:00 AM
2CARPRO JACK
  • 11,533 POSTS
unfortunatly there is no easy way to get at those bolts.The locking nuts for the tensioners are 15mm heads and you may be able to get at them easier from underneath the car.
Jun 25, 2010 at 10:10 AM
