1999 Chrysler Sebring Front brakes heating up
96,000 MILES • 6 CYL • FWD • AUTOMATIC
BMER622
I've been trying to diagnose what is causing the brake squealing (pad are new & noise didn't stop). While spraying the tires at the car wash (Tire Cleaner setting / very low pressure) that quite a bit of steam was produced (from the brakes) when the water hit both front wheels. This was after spending 15-20 minutes cleaning the convertible top.
What could be causing the brakes to get so hot? Could that problem be the cause of the annoying brake squeal?
Sep 28, 2009 at 5:37 PM
  • 75,988 POSTS
Could be the caliper pistons not retracting due to its corroded or binding to include the ABS unit.
Sep 28, 2009 at 5:43 PM
