1999 Chrysler Sebring Check Engine Light On
KAYCESMAMA
  • 1999 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 180,000 MILES
Car is idling rough and needs a flex pipe put on and check engine light is on. New plugs and map air flow sensor was put on car. Now when the car is running there is a clicking noise, the rpms rev up when you give it just a little gas and it has less power
Thursday, July 22nd, 2010 AT 12:57 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve
Thursday, July 22nd, 2010 AT 6:11 PM
