1999 Chrysler Sebring Belts
DJONES834
  • 1999 CHRYSLER SEBRING
  • 6 CYL
  • 80,000 MILES
How can I change the belts on a 1999 Chrysler Sebring? AC/Alternator belt broke, but I need to take off the PS belt first, that is where I'm hung up.
THank you!
Monday, February 23rd, 2009 AT 11:26 AM
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_Chrysler_Cirrus_00033286_6.jpg
Raise vehicle. Remove passenger side wheel. Remove wheel well cover. Behind the P/S pulley, locate the pivot bolt and two lock bolt. Loosen all of them (15mm wrench). Replace belt. To tighten, attach 1/2" ratchet onto the pivot hole push to tight. Tighten the three bolt. Test for tension. Reverse the rest to finish installation.
For the alt/AC, loosen the idler pulley. Remove and replace the belt. Tighten idler pulley.
Monday, February 23rd, 2009 AT 11:39 PM
