1998 Chrysler Sebring Vehicle will not start!
101,000 MILES • 6 CYL • FWD • AUTOMATIC
GCUNDIFF
Car had been running fine with no signs of any problems starting. Tried to start the car and nothing happend.
The battery seems to be charged...but only half of the equipment works now when the ignition is turned on. the fan to heater works...the electric windows work..hazards work, lights are fine (hi and low) interior lights are on.........power top won't work...turn signals -no, dash gauges and lights do not illuminate.
When ignition is turned the brake light illuminates but nothing else and no power to starter...
Any ideas?
Thanks
Gary
Sep 6, 2009 at 7:52 AM
JDL
  • 16,098 POSTS
I'd check the circuits at the starter relay in the power distribution center. The voltage for the load side of relay is hot all the time. The voltage for the coil side of relay, goes hot with the key in the crank position. You pull the relay, use a testlite, with key in the crank position, see how many hot terminals you have? Make sure the tranny is in park or neutral and the e-brake is set. Did you try cranking in neutral?
Sep 6, 2009 at 9:01 AM
