1998 Chrysler Sebring Spark plugs
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGWAGON7
My daughter was driving the other morning (after I had warmed up her car) and the car just died in the middle of the road. We've replaced the battery and have determined that wasn't it. My husband has checked all of the fuses and has found out that there is no power going to the spark plugs. What is the best way to find out what has happened? Is it just a matter of search and find or is there something else? Thank you.
Feb 12, 2010 at 8:02 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 12, 2010 at 7:47 PM
