1998 Chrysler Sebring PUMP WATER
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIGUEL CUENCA
HOW I FIX HO CHANGE[img:78e61456d3]http://www.2carpros.com/forum/automotive_pictures/270304__2.jpg[/img:78e61456d3]
Nov 12, 2008 at 7:19 AM
ZACKMAN
  • 4,202 POSTS
Jack up the car.
Remove tire.
Remove splash shield.
Remove drive belts.
Remove the crank pulley
Put a jack under the motor.
Remove front engine mount.
Remove the timing covers (you may have to move the P/S pump out of the way).
Remove the timing belt, remove the water pump, and reinstall. Make sure that the o-ring in the back of the water pump seats in properly before you bolt it up. It is advisable that you replace the timing belt at the same time.
Nov 12, 2008 at 12:27 PM
