1998 Chrysler Sebring Hub bolt removal (can't afford to bre
14,500 MILES • 6 CYL • FWD • AUTOMATIC
CARPDOGSCOTT
I have tried everything to remove cv bolt(hub bolt)! I have used a cheater, even heated it up pretty good. I have removed the cotter pin, what am I missing, reverse thread? Please help, can't afford to break any more tools!!
Dec 17, 2008 at 6:03 AM
DOCFIXIT
  • 18,828 POSTS
You can rent an electric impact use a 6 point socket. Go forward and reverse to break loose. If no impact 6 point socket 1/2 in breaker and about 4 ft pipe again right then left till it breaks loose then lefty loosey
Dec 17, 2008 at 7:02 AM
