1998 Chrysler Sebring HOWLING NOISE
150,000 MILES • 6 CYL • FWD • AUTOMATIC
HACKR01
I have a definite howling noise coming from my left front wheeo area. I have checked the bearings and they seem to be OK (no wobbling).Is there other bearings in the wheel area. I have checked the alternator, it is OK.
Is there any ither bearing in the axel? What else can I check?
Thanks for your assistance.
Ron Hackett
Nov 18, 2009 at 8:12 PM
BMRFIXIT
  • 19,053 POSTS
in many cases you may not see any movement even though the bearing is at fault
drive the car on a smooth straight road
and try to steer little to the left and little to the right (driving like a drunk )
as you maintaining the speed does the noise fade away or change and if so 99%bearing is at fault
Nov 18, 2009 at 10:16 PM
