1998 Chrysler Sebring hesitation
101,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFREY1
momentary lack of respond when accelerator is pressed can accure at any speed usually most severe when starting the car when comming to a comprete stop which cause engen to stall almost comming to a complete stop
May 14, 2010 at 1:33 AM
JDOG+1
My 1998 did the same thing. check you distributor cap, and rotor. mine where carbon tracked and also the idle. If those dont work it could be distributor starting to go out. there is no way to test it.
Jun 12, 2010 at 9:13 PM
