1998 Chrysler Sebring Engine smokes while idling
126,325 MILES • 6 CYL • FWD • AUTOMATIC
DMGRAHAM
I bought a used Chrysler Sebring that has been very well maintained. However a month after I bought the car I noticed it would smoke while idling at a drive thru. I took it to a machanic that changed the PVC value but it is still smoking. It is not using oil. I had the oil changed and ten weeks later it isn't even down a quart.
Mar 7, 2009 at 12:39 AM
BMRFIXIT
  • 19,053 POSTS
Something is leaking
need to have it checked
check coolant and do a coolant pressure test
recheck tranny lines and recheck for oil leaks
Mar 7, 2009 at 12:47 AM
DMGRAHAM
Would a leak cause the car to smoke from the exhaulst system?
Mar 7, 2009 at 1:08 AM
BMRFIXIT
  • 19,053 POSTS
Out the tail pipe ?
check coolant system and headgasket
If its very cold condensation
Mar 7, 2009 at 10:51 AM
