1998 Chrysler Sebring DISTRIBUTOR
12,300 MILES • 6 CYL • FWD • AUTOMATIC
GILBOY42
I INSTALL A NEW DISTRIBUTOR BROUGHT THE NUMBER 1 PISTON TO TOP DEAD CENTER ROTOR ON NUMBER 1 WILL NOT START PLUGS GET WET WITH GAS
Dec 5, 2009 at 4:53 AM
  • 75,988 POSTS
Do you have spark if so double check the valve and ignition timing could be off 180deg out-
Dec 5, 2009 at 6:14 AM
