Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Sebring
Ignition
Distributor
Replace/Remove
1998 Chrysler Sebring DISTRIBUTOR
1998 CHRYSLER SEBRING
12,300 MILES • 6 CYL • FWD • AUTOMATIC
GILBOY42
MEMBER
1 POST
I INSTALL A NEW DISTRIBUTOR BROUGHT THE NUMBER 1 PISTON TO TOP DEAD CENTER ROTOR ON NUMBER 1 WILL NOT START PLUGS GET WET WITH GAS
Dec 5, 2009 at 4:53 AM
Experienced Mechanic
Do you have spark if so double check the valve and ignition timing could be off 180deg out-
Dec 5, 2009 at 6:14 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
