1998 Chrysler Sebring Crank sensor and camshaft sensor
232,000 MILES • 6 CYL • FWD • AUTOMATIC
LDAVE1975
Can you please tell me where the crank sensor and the camshaft sensors are located?
Mar 6, 2009 at 12:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The 6-cylinder engines are equipped with a camshaft driven mechanical distributor, which is equipped with an internal camshaft position (fuel sync) sensor.
Therefore, if the camshaft position sensor fails, the distributor assembly must be replaced.
The crankshaft position sensor is located on the transaxle housing, near the left side strut tower. You may need to remove the speed control servo unit to gain access to the sensor..
Thanks for using 2CarPros.com!
Dec 30, 2020 at 4:21 AM
