1998 Chrysler Sebring Car will not start.
185,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMSVOBO
When I turn the key to start the car nothing happens. the battery is fully charged and the only dummy lights that come on are the brake light and the odometer/transmission position indicator. the headlights work, I can turn on the heater/ac fan but the radio will not come on or the chech engine,oil, dummy lights. the dome lights come on but care will not turn over. Could it be a battery cable connection issue or a fuse or fusible link? I need to get it running ASAP. Please help me!
Jul 26, 2008 at 5:06 AM
MASTERTECHTIM
  • 4,750 POSTS
yes check big fuses under hood. double check the battery connections. also its possible the ignition switch is bad. check fuses first
Jul 26, 2008 at 11:54 PM
