1998 Chrysler Sebring
BUD1028
1998 Chrysler Sebring 6 cyl Automatic
I've replaced the crank sensor and distributor and my car still does'nt get any fire. It turns over it just won't start. What can I do?
Apr 22, 2009 at 2:31 AM
JDL
  • 16,098 POSTS
Hello, Is the asd relay energized, engine cranking? The dark green wire with orange tracer at the distributor and injectors, should be hot with engine cranking? If I suspect the crank or cam sensor, I don't replace those without checkng the sensor circuits.
Apr 22, 2009 at 3:43 AM
BUD1028
I will have to check it. I'm at work so it will be a little while, also I would give a donation but I don't have a credit card.
Apr 22, 2009 at 3:57 AM
