1997 Chrysler Sebring timming belt cover
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
EPRUNEAN
I'm having trouble removing the upper right cover of the timming belt because the steering pump mounting bracket is blocking it. The mannual sais to remove this bracket but they don't give any details about how to do that. does anybody know how can u remove this this timming belt cover? Thanks
Mar 2, 2010 at 9:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
use the inner fender hole to access and remove bolt attaching top of power steering pump front bracket to cast aluminum mounting bracket. then remove belt and remove PS pump and bracket.
Mar 2, 2010 at 2:32 PM
THE HACK
Wow...someone else is feeling my pain! I've been working on that bracket for days.There are bolts you can't get to with mortal means. If you find a way,let"the hack" know.The manuals are so vague,they don't help much.Good luck,buddy.
Apr 2, 2010 at 6:45 AM
