1997 Chrysler Sebring Timing Belt
165,000 MILES • 4 CYL • FWD • AUTOMATIC
CAOS38
I have a 97 Chrysler Sebring and had to replace the timing belt due to a water pump going out and now I can not seem to get the timing set so the car will start
Feb 20, 2010 at 7:29 AM
  • 110,248 POSTS
Is the belt the problem or the distributor?
Jul 30, 2019 at 9:07 AM
CAOS38
Its a timing issue...I had to replace the belt and water pump and now the car will crank but not start but it will back fire at first when you crank it
