1997 Chrysler Sebring Tach & Odometer
106,000 MILES • 6 CYL • FWD • AUTOMATIC
D1059
My tach and odometer work intermitently. is there a fuse or relay i might have missed? I pulled all the fuses and relays and there all good. don't know if there's another one i missed
Thank you, Doug
May 2, 2009 at 6:25 AM
SURGEMAN
[quote:7787079261="D1059"]Electrical problem
1997 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 106000 miles
Thank you, Doug[/quote:7787079261]
Doing the same thing myself right now...Pull the the gauge panel....Pull the card board protector off the back..and there is an area that looks like it takes alot of heat...There's a diode right in that area with 2 resistors that looks like they get real hot...look on the solder joint itself..and see if it has a ring crack around it....That feeds voltage to the odometer for milage....Doing the repair now...I'll let you know how it goes.I know sucks huh..lol....Take care..Jeff
May 26, 2009 at 2:02 PM
